geodd
May 09, 2020Aspirant
Nighthawk AC1900 WiFi Cable Modem Router
I would like to know if there are any current Netgear mesh systems that will work with my existing cable modem router? If not, any suggestions?
May 09, 2020Guru - Experienced User
You have the C7000?
You can always use a mesh extender and it'll work. If you're needing more than 1 extender, i'd recommend running a full mesh system like orbi though. Mesh extenders work great until you need mutliple ones and then you can run into issues. not everyone has them but it happens often enough I recommend Orbi versus multiple mesh extenders.
You can put the C7000 in modem only mode and run a setup like Orbi.
Or even run the C7000 in modem and router mode and Orbin in Access point mode.
- geoddMay 09, 2020Aspirant
Thanks for your reply . That's what I wanted to know and will do.
George
