scorpio907
Oct 17, 2024Aspirant
Nighthawk AC1900 WiFi Cable Modem Router(C7000v2)
Upon setting up my Nighthawk AC1900 modem, I'm getting speeds from 2.0 mbps around 50 mbps with my PC. Have only up to two devices being used and should be getting, per my contract with Xfinity, up ...
Oct 17, 2024Guru - Experienced User
Is the PC ethernet connected or wireless connected?
What channels are you using? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Smart Connect enabled?
Brand and model# of the PC and wireless or ethernet adapter installed in the PC?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
What browser are you using. Be sure to clear out all browser caches before entering the modems web page.
Try a different browser, MS Edge or Firefox?
Has a factory reset and setup from scratch been performed since last FW update? Factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
scorpio907
Thanks for the reply, FURRYe38. PC is connected as wireless. I did try connecting directly via Ethernet adapter but still only got about 50 GHz of speed. Using Protocol Wi-Fi 4 (802.11n); network channel is 1. Using Dell Inspiron, Using Firefox browser. Tried connecting to 198.162.1.1 and that one "times out"; the same issues occur with MS Edge with both 192.168.1.0 and 192.168.1.1 after clearing the cache. Whatever Smart Connect is set as by default is where it's at currently (unable to go into modem settings to verify which). Had hit the reset button on the modem but no "factory" reset has been done. May need to try that. If I can just log into routerlogin.net or either of the two IP's I'd be able to get much further on this issue.
- FURRYe38Oct 17, 2024Guru - Experienced User
Id disconnect the modem from the ISP coax cable and then press the reset button for 15 seconds then release. With a wired PC connected to the back of the modem, give 2 minutes, then try accessing the modems web page and setup wizard should be seen at 192.168.1.1 in the web browser.
- scorpio907Oct 18, 2024Aspirant
I tried that and, sadly, it made no difference. At this point, thinking it could be a firmware issue. Your suggestions?
- FURRYe38Oct 18, 2024Guru - Experienced User
OK, with same ISP cable not connected to the modem, try a 30-30-30 reset on the modem and see if this can get you to the setup screen with a ethernet connected PC. Be sure to try 192.168.1.1 or .192.168.0.1.
