LittleLisa
Aug 07, 2023Aspirant
NightHawk AC1900 WiFi Model C7000
I replaced Xfinity's router with the one in the subject line to try to save some money. It was a grueling experience getting it hooked up due to Comcast's poor customer service. I finally got it set ...
- Aug 08, 2023
Thank you for your reply. I contacted Xfinity again. The bot on the phone said there was a problem and a technician had to come out. He just left. two of my cable lines were bad, giving intermittent service. He found a good one in a spare room and set everything up correctly and it now all works! Even the Kindles! So I've learned that intermittent service is most likely the lines into the house. He said they were bad. The house is 18 years old so I guess they age and wear out. Thank you again for your reply and helpful info. I'm sure it will also help others.
Aug 07, 2023Guru - Experienced User
C series modems don't have captive portals.
Factory reset the modem and setup from scratch. Press the reset button in back for 10 seconds then release.
Use a ethernet connected PC behind the modem with a web browser to setup the modem at 192.168.1.1. Then you can configure the wifi ssid name and give a new password. I recommend a new custom SSID name, and password here.
- LittleLisaAug 08, 2023Aspirant
- FURRYe38Aug 08, 2023Guru - Experienced User
Glad then got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
