Task-DL's avatar
Task-DL
Nighthawk AC3200 C7800 - Wireless settings either not saving or if they do they reset to default
Hello,   Want to start using my Ac3200 C7800 as a wireless router with ORB units.   Enable by button onthe front the Wireless - lights come on for 2.4 and 5Ghz. Disable the WPS by button on fron...
  • FURRYe38's avatar
    Sep 12, 2020
    The C series modem isn't compatible with Orbi systems.
    Your best bet would be to set the C series modem to disable router mode, running it in modem only mode, then connect your Orbi system to the modem. The Orbi wifi system is way better than the C series modem.
