Task-DL
Sep 12, 2020Aspirant
Nighthawk AC3200 C7800 - Wireless settings either not saving or if they do they reset to default
Hello, Want to start using my Ac3200 C7800 as a wireless router with ORB units. Enable by button onthe front the Wireless - lights come on for 2.4 and 5Ghz. Disable the WPS by button on fron...
- Sep 12, 2020
The C series modem isn't compatible with Orbi systems.
Your best bet would be to set the C series modem to disable router mode, running it in modem only mode, then connect your Orbi system to the modem. The Orbi wifi system is way better than the C series modem.
Task-DL
Sep 14, 2020Aspirant
FURRYe38,
Thanks for the information, will go that route.
To set C7800 in Modem only mode is there a setting box for that or just disable all Wireless settings and press button on front of device?
Thanks again.
DL
Sep 14, 2020Guru - Experienced User
Yes, look for router mode under Advanced tab. Select No.
- Task-DLSep 15, 2020Aspirant
FURRYe38 - Strange as I do not see that setting at all on my modem.
Please see attached screenshots.
Would you happen to know why I would not have that setting?
Thanks in advance.
DL
