Loosechange
Jan 15, 2024Tutor
Nighthawk AX2700 plugged power in and only the 1234 lights are on.
Hi all today the device start giving issue. cannot connect to the internet and performed a reset. now the only lights that come on are the 1,2,3,4 lights nothing else. ANY ADVICE will be much appreci...
Jan 16, 2024Guru - Experienced User
are you able to log into the device and navigate its GUI?
- LoosechangeJan 16, 2024TutorNo I cannot, even tried using the app to reboot / rest will not connect.
- FURRYe38Jan 16, 2024Guru - Experienced User
If you disconnect the ISP coax cable from the modem, then press the reset button for 10 seconds then release, does the top power led then turn ON?
- LoosechangeJan 16, 2024TutorNo will not do anything
