DannyS22
Dec 12, 2021Guide
NightHawk AX2700/CAX30
Nighthawk ax2700/cax30 firmware 1.4.10.8 I'm on Xfinity cable with their More Speed Plan (I think) Seems that every 2 weeks I need to power off/power on the unit to get back my speeds. As an ex...
- Dec 13, 2021
Keep us posted.
DannyS22 wrote:
I still don't see anything called WMM under the advance wireless setup
I've changed the channels but I get a message on the 5Gmhz that says To get best wireless performance Netgear recommends set gateway to a high channel between 149-161. I proceded to 48.
It will take a while to see if things change.
Thanks for the help.
danny
DannyS22
Dec 13, 2021Guide
Let me see if I've got the right info.
NO Ethernet connections ALL wireless.
Wireless Setup
Enaable AX
2.4Ghz
Enable SSID Broadcast
Enable 20/40 Mhz Coexistence
Channel Auto: Current 8
Security: WPA-2 Personal [AES]
5.0Ghz
Enablr SSID Broadcast
Channel 153
Current 147+153(P)+157+161
Security WPA-2 Personal (AES)
Maybe 1 neighbor with a WiFi
SMART is NOT enable and I don't know WMM (sorry)
Seems to me as a novice, it's like resetting the connection. I don't know if Xfinity is throttleing me. According to their website, I'm not close to data limit, if there is one.
THANKS for the help, I appreciate it.
Danny
Dec 13, 2021Guru - Experienced User
So try this, Disable WPA security on the modem temporarily. Connect 1 device up to the CAX while the wifi is in the open. See if it will connect and gain internet services. Re-enable WPA2 and AES after testing.
Wireless Setup
Enaable AX
2.4Ghz
Channel Auto: Current 8< Try channel 1, 6 or 11.
5.0Ghz
Channel 153
Current 147+153(P)+157+161< Try channel 48.
SMART is NOT enable and I don't know WMM (sorry) < Under Advanced Tab/Advanced Settings/Wireless Settings
Danny
