DannyS22
Dec 12, 2021Guide
NightHawk AX2700/CAX30
Nighthawk ax2700/cax30 firmware 1.4.10.8 I'm on Xfinity cable with their More Speed Plan (I think) Seems that every 2 weeks I need to power off/power on the unit to get back my speeds. As an ex...
- Dec 13, 2021
Keep us posted.
DannyS22 wrote:
I still don't see anything called WMM under the advance wireless setup
I've changed the channels but I get a message on the 5Gmhz that says To get best wireless performance Netgear recommends set gateway to a high channel between 149-161. I proceded to 48.
It will take a while to see if things change.
Thanks for the help.
danny
DannyS22
Dec 13, 2021Guide
danny
Dec 13, 2021Guru - Experienced User
Keep us posted.
danny
- DannyS22Jan 11, 2022Guide
Well it's been almost a month since I made the changes on the chanels. Things appear to be working great. No more isses and my remote thermostats haven't lost connects either.
THANKS for the help.
Danny
