Duddy03
Dec 17, 2023Aspirant
Nighthawk AX6 Cable Modem Router-Using ReadyShare
Hi I have successfully connected a Seagate 14 TB "Expansion" HD to my home Wi-Fi using ReadyShare. Now I am looking for a flexible backup software that will give me full control on what needs to be...
michaelkenward
Dec 18, 2023Guru - Experienced User
Duddy03 wrote:
However, I have read that ReadyShare already gives me that capability.
Where did you read that? Is it mentioned in the manual for your Netgear device?
Which Nighthawk Cable Modem Router do you have?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Remember that Netgear has abandoned some ReadySHARE features, such as ReadyCLOUD.
Support for ReadyCLOUD feature ends spring 2023 | Answer | NETGEAR Support
Data will have to flow from a laptop thumb drive wirelessly to the Netgear Knighthawk and USB-connected Seagate HD.
In other words, the backup task is from laptop to ReadySHARE USB over wifi?
Does this laptop come with any backup software?
What do you use to backup the laptop itself?
There are many different backup options out there. The choice depends on what you want to do. I like SyncBack:
Backup Software that does everything you need, and much more
But that is a personal preference. Others here may have their own favourite.
This isn't really the best place to get that sort of advice.
