poormr
Jan 24, 2022Tutor
Nighthawk AX6000 (CAX80) add Mesh System
I have a Nighthawk AX6000 (CAX80) wifi cable modem router and I want to add a tri-band mesh system to my home. I have about 4,000 square feet. I am confused, should I install a Orbi mesh system o...
Jan 24, 2022Guru - Experienced User
I would focus more on if you're wanting a dual band or a triband system.
The MK and the orbi perform similar when they have similar specs so its more about what performance system you're adding.
poormr
Jan 24, 2022Tutor
I want to add a tri-band system but I didn't know what the difference was or the best between between the Orbi mesh systems or the Nighthawk mesh systems. Maybe I am just splitting hairs.
- plemansJan 24, 2022Guru - Experienced User
a lot depends on the performance/budget you want.
In terms of performance/capabilities it'd go base system for triband: MK80 series, then obri 7 series, then 8, then 9 series.
But they go up in price each step.
- poormrJan 24, 2022Tutor
THANKS for the insight. I'll look into the MK80 series. Take care.
