Atomrow's avatar
Atomrow
Follower
Feb 27, 2023
Nighthawk AX6000 (model CAX80) Uploads time out
Hello,
I have an issue where files time out when uploading (although its not every time, but most times). I believe its a router configuration issue because if i switch the WIFI to use my iphones hotpot it resolves. Thoughts? TIA
1 Reply
  • FURRYe38's avatar
    What brand and model devices are you using when uploading over 5Ghz?
    Ya, the CAX80 has a known problem with uploads over 5Ghz. Trying to help narrow down what devices are effected.
    I've seen some Realtek adapters work fine over 5Ghz.
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    How is the Basic and Advanced WiFi configured on the CAX80?
    Who is the ISP that you use?
