RobbieB9969
May 06, 2022Tutor
Nighthawk AX6000 Not working
Nighthawk AX8 AX6000 Model #: CAX80 I have noticed my nighthawk is not online. The power button is solid white, but none of my other icons green. I have tried a hard reset, but nothing has happ...
RobbieB9969
May 06, 2022Tutor
No I am not able to login on the app. However, my cable is working fine.
May 06, 2022Guru - Experienced User
Not using the app. But using a web browser to access its IP address
- RobbieB9969May 06, 2022Tutor
I cannot connect that way either.
- plemansMay 06, 2022Guru - Experienced User
Does your connection work? You're just not able to connect to login?
No, the connection does not work. Even Comcast cannot connect to the router. It is reading offline on their end. As you can see from the picture, only the power button is indicating on as solid whiteNothing
disconnect the coax from it and try a reset with coax disconnected. push and hold reset for up to 30 seconds while powered on.
Do the led's change at all when you're trying it?
It should boot loop without a cable connected. Trying to see if its failing in its detection
