Oscarbola
Aug 03, 2020Follower
Nighthawk AX8 cable modem router and Orbi RBR50 blocking sites and apps from connecting
After installing a new Nighthawk AX8 cable modem router and connecting it to my existing Orbi RBR 50 set normal and harmless websites are being blocked and ask for passwords, or 404 errors occur. Al...
Aug 04, 2020Guru - Experienced User
Which AX8 cable modem router did you install?
After the install, did you put the orbi in access point mode?
otherwise you'd have a double nat setup.
