spacetoilet
Dec 14, 2020Aspirant
Nighthawk AX8 Cable Modem Router CAX80 PLEASE HELp terrible wifi speeds
I recent purchased this Modem/Router so I didn't have to rent from Comcast. I have a Gigabyte package ( I get about 940 down) but my wifi speeds are garbage on this equipment, like mid 50's max. On ...
Dec 15, 2020Guru - Experienced User
I've used the CAX80 and it does work great.
I can hit around 400-500mbps over the 5g, and roughly 70-110mpbs over the 2.4ghz depending on time of day.
What speeds do you get hardwired into it?
Since install, did you ever try a factory reset and install?
spacetoilet
Dec 15, 2020Aspirant
I get almost 950mbps down on wired. Already factory reset, not sure what you mean by install?
- FURRYe38Dec 15, 2020Guru - Experienced User
What wifi devices are you using to speed test?
What wireless settings are you using on the CAXIs Armor active on the CAX?
- spacetoiletDec 17, 2020Aspirant
I'm using an iphone X and a 2018 ipad pro to test wifi speeds. As I did the hard reset the only different setting is the channel, and I have tried all of them with barely any difference.
- FURRYe38Dec 17, 2020Guru - Experienced User
Load up wifi sweetspots on your phone and pad and check the connection rate speeds seen with these connected with the CAX80.
