spacetoilet
Dec 14, 2020Aspirant
Nighthawk AX8 Cable Modem Router CAX80 PLEASE HELp terrible wifi speeds
I recent purchased this Modem/Router so I didn't have to rent from Comcast. I have a Gigabyte package ( I get about 940 down) but my wifi speeds are garbage on this equipment, like mid 50's max. On ...
spacetoilet
Dec 15, 2020Aspirant
I get almost 950mbps down on wired. Already factory reset, not sure what you mean by install?
Dec 15, 2020Guru - Experienced User
What wifi devices are you using to speed test?
What wireless settings are you using on the CAX
Is Armor active on the CAX?
- spacetoiletDec 17, 2020Aspirant
I'm using an iphone X and a 2018 ipad pro to test wifi speeds. As I did the hard reset the only different setting is the channel, and I have tried all of them with barely any difference.
- FURRYe38Dec 17, 2020Guru - Experienced User
Load up wifi sweetspots on your phone and pad and check the connection rate speeds seen with these connected with the CAX80.
Ok so first of all I stumbled accross an option called:- enable 20/40mhz coexistence, and unchecked it. This improved my speeds but still seem bad. I used the Wifi Sweetspots app and it topped out at 85. Again, I'm on a gigabyte package from xfinity (which in real world on ethernet is getting about 940-950 down). I just don't understand why the wifi is slow bad.
