dandod
Mar 17, 2021Guide
Nighthawk AX8 CAX80 in boot loop with solid white power light
Hi, everyone! I have had this cable modem router since November (four months ago) and it has worked perfectly up until yesterday. It was powered off and since then has not been able to work again. ...
Mar 17, 2021Guru - Experienced User
FYI, if signal is lost on the CAX80 coax line, it will do a boot loop until the signal is regained and reacquired from the ISP. This is the only model that does this. By NG design.
