dandod
Mar 17, 2021Guide
Nighthawk AX8 CAX80 in boot loop with solid white power light
Hi, everyone! I have had this cable modem router since November (four months ago) and it has worked perfectly up until yesterday. It was powered off and since then has not been able to work again. ...
dandod
Mar 18, 2021Guide
It was on a UL-listed good quality surge protector, but I am wondering if something did happen to brick it. I'll see what NG Support can do. Thanks, everyone!
(If there is a way to fix it, I'll update this thread.)
dandod
Mar 20, 2021Guide
Went through the steps with support and they were perplexed as well. It is RMA'd and will be replaced. I wish I could find out what it was in case I can prevent it from happening again!
