Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
vkdelta
Aug 19, 2020NETGEAR Employee Retired
can you please post a pcap capture.
Does it happen on wired connection as well?
did you try with DMZ? (just for test purposes)
- Foo_King_DeadSep 15, 2020TutorI will post pcap. I did try DMZ but no luck. It’s also wireless
- kirby30500Jan 06, 2021Aspirant
What is a "pcap"?
- FURRYe38Jan 06, 2021Guru - Experienced User
I believe that is a file made by wireshark networking scanning program...
kirby30500 wrote:What is a "pcap"?
