Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
vkdelta
Aug 23, 2020NETGEAR Employee Retired
can you please post a pcap capture.
Does it happen on wired connection as well?
did you try with DMZ? (just for test purposes)
jlbennettmd
Sep 15, 2020Guide
I had same experience with cax80 and cisco anyconnect. work is not seeing any traffic on port 4500 as they do with old device.
- Keithg1229Sep 16, 2020Tutor
I did try forwarding my ports to 4500, but no dice. Mind you, I have no idea what I am doing so there may be more to it.
My version of Anyconnect is old (4.5x) and my company is changing VPNs so we have no support for Cisco to get the newest version. Me wonders if the update is necessary. Pure speculation, but this router is so new and the version of Anyconnect I have is no longer supported.
