Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
Keithg1229
Sep 16, 2020Tutor
Sorry for late reply.
I did try wired connection, and DMZ.
My I.T. Dept has determined that since we are changing VPNs at some point that it wasn't worth the effort to keep troubleshooting and gave me a MiFi device for now.
Honestly I do not think Netgear is the problem since every other VPN used works fine.
jlbennettmd
Sep 16, 2020Guide
If I use personal hotspot bypassing cax80 I am able to connect.
- jlbennettmdSep 16, 2020GuideAlso, if I use C7100V; VPN also works
- jlbennettmdSep 23, 2020GuideI also switched to another new router and modem and vpn works fine.
- FURRYe38Sep 23, 2020Guru - Experienced User
Please keep in contact with NG support.
Thank you.
