Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
jlbennettmd
Sep 16, 2020Guide
If I use personal hotspot bypassing cax80 I am able to connect.
jlbennettmd
Sep 16, 2020Guide
Also, if I use C7100V; VPN also works
- jlbennettmdSep 23, 2020GuideI also switched to another new router and modem and vpn works fine.
- FURRYe38Sep 23, 2020Guru - Experienced User
Please keep in contact with NG support.
Thank you.
- jlbennettmdSep 23, 2020GuideSo three modems in two weeks and only the CAX80 fails.
- KimikaziMay 09, 2021Tutor
What devices have you found to work with Cisco AnyWhere Connect?
- cashtagMay 09, 2021Guide
Other netgear products besides this model, Tlink, ubiquiti, my Hot wifi. You name it - they *all* work except for this particular netgear model. Literally, of all the ones I tried, this is the *ONLY* one that does not work.
