Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
Jan 07, 2021Guru - Experienced User
Yes I was wondering if the DMZ on the modem would work as a quick test. Not long term.
The question about the external wifi router would be to see if you put the modem in to modem mode only and connect your wifi router to the modem, same things happens or does it work? Something to try and give feedback to NG support on.
cashtag
Jan 07, 2021Guide
FURRYe38 wrote:Yes I was wondering if the DMZ on the modem would work as a quick test. Not long term.
I see - just tried it on modem mode and it does connect. But I disconnected immediately. My company has an "honor system" policy to use the router. I don't think they would ever know - but I still don't want to risk it. So, at the end of the day, the router must work. But yes, modem mode does work.
- FURRYe38Jan 07, 2021Guru - Experienced User
Ok so sounds like someting on the router side of the modem when in router mode is causing prolems. This is something to pass on to NG support. Seems that this needs to be fixed.
