Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
jlbennettmd
Sep 23, 2020Guide
I also switched to another new router and modem and vpn works fine.
Kimikazi
May 09, 2021Tutor
What devices have you found to work with Cisco AnyWhere Connect?
- cashtagMay 09, 2021Guide
Other netgear products besides this model, Tlink, ubiquiti, my Hot wifi. You name it - they *all* work except for this particular netgear model. Literally, of all the ones I tried, this is the *ONLY* one that does not work.
- KimikaziMay 09, 2021Tutor
We'll see, I have a CM1000 arriving today, I'm beginning to think it is the modem/router combination that is the cause. I had the same issue with the Xfinity modem/router previously. I used a CM500 successfully for years until I wanted more speed. I guess I'll be returning the CAX80, as I need the Cisco Anywhere Connection to work from home.
- jlbennettmdMay 09, 2021GuideI am using CM1150V and RAX200. I know others using CM1200 and RAX120 also working well with Cisco Anyconnect
