Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
Kimikazi
May 09, 2021Tutor
What devices have you found to work with Cisco AnyWhere Connect?
cashtag
May 09, 2021Guide
Other netgear products besides this model, Tlink, ubiquiti, my Hot wifi. You name it - they *all* work except for this particular netgear model. Literally, of all the ones I tried, this is the *ONLY* one that does not work.
- KimikaziMay 09, 2021Tutor
We'll see, I have a CM1000 arriving today, I'm beginning to think it is the modem/router combination that is the cause. I had the same issue with the Xfinity modem/router previously. I used a CM500 successfully for years until I wanted more speed. I guess I'll be returning the CAX80, as I need the Cisco Anywhere Connection to work from home.
- jlbennettmdMay 09, 2021GuideI am using CM1150V and RAX200. I know others using CM1200 and RAX120 also working well with Cisco Anyconnect
