Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
Aug 19, 2021Guru - Experienced User
To anyone in this thread can help provide a Wireshark PCAP trace log of when this happens with the VPN while trying to connnect thru the CAX80, please let me know.
vkdelta
Aug 19, 2021NETGEAR Employee Retired
PCAP instructions for laptop
- vkdeltaAug 19, 2021NETGEAR Employee Retired
CAX80 debug instructions
pls use BOTH the files (and above file as well)
and PM (Private message) both the logs (dont paste the files here)
- lopesmatttaliNov 03, 2021AspirantNighthawk AX8, Model CAX80I have just purchased this netgear equipment, and while my signal is great, I am not able to connect to my work CISCO VPN and I need this fixed ASAP. Are you able to help me?
- Foo_King_DeadNov 03, 2021TutorUnfortunately I can’t help you because the Netgear team refuses to respond or admit they have a problem sending packets to Cisco VPN. They should rename this model from CAX80 to SUX80
- cashtagNov 03, 2021Guide
Only way I got it to work is by bypassing the router. I've since got another router. In short, I gave up.
cashtag Foo_King_Dead vkdelta what model do you recommend i get when I return this one
