Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
Khannroy-Dakota
Dec 10, 2021Tutor
Hey I was having the same issues.
I have firmware V2.1.3.5
I did the following:
1. go to advanced settings
2. go to Setup
3. go to WAN Setup
4. Disable IPSEC ALG
This allowed me to connect.
Hope this helps
- dv8withn8Dec 10, 2021Tutor
Yes, this is what Netgear recently suggested to me as well and it did solve the issue. The **bleep**ty part is, it took them 9 months to provide a working solution.
- Khannroy-DakotaDec 10, 2021Tutor
Wow - that's like way too long for such a simple and direct resolution.
Well as long as your back up that all that matters.
Now - get back to work - LOL
- FURRYe38Dec 10, 2021Guru - Experienced User
So enabling that feature causes the problem?
