Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
lopesmatttali
Nov 03, 2021Aspirant
I have just purchased this netgear equipment, and while my signal is great, I am not able to connect to my work CISCO VPN and I need this fixed ASAP. Are you able to help me?
Khannroy-Dakota
Dec 10, 2021Tutor
Disable IPSec ALG.
Advanced > WAN Setup >
Check the box next to Disable IPSec ALG
then click on the apply button [bottom right]
should allow the response back from your work server to get out and back
Tactfully,
Khannroy Dakota
