Foo_King_Dead
Aug 12, 2020Tutor
Nighthawk AX8, Model CAX80
Just purchased the new Nighthawk AX8 - CAX80 modem/router. After getting it set up on my Spectrum internet service I can't VPN into my work.. I've checked all parameters and have spent hours on the p...
Khannroy-Dakota
Dec 10, 2021Tutor
Hey I was having the same issues.
I have firmware V2.1.3.5
I did the following:
1. go to advanced settings
2. go to Setup
3. go to WAN Setup
4. Disable IPSEC ALG
This allowed me to connect.
Hope this helps
dv8withn8
Dec 10, 2021Tutor
Yes, this is what Netgear recently suggested to me as well and it did solve the issue. The **bleep**ty part is, it took them 9 months to provide a working solution.
- Khannroy-DakotaDec 10, 2021Tutor
Wow - that's like way too long for such a simple and direct resolution.
Well as long as your back up that all that matters.
Now - get back to work - LOL
- FURRYe38Dec 10, 2021Guru - Experienced User
So enabling that feature causes the problem?
