Dustin_V
Jun 16, 2020NETGEAR Employee Retired
Nighthawk AX8 WiFi 6 Cable Modem Router Is Now Available!
NETGEAR is excited to announce that the Nighthawk AX8 8-Stream WiFi 6 Cable Modem Router (CAX80) is now available! An Innovation Award Honoree at CES 2020, the Nighthawk CAX80 is the first of its...
Jun 17, 2020Guru - Experienced User
Do you order thru NGs shop site?
visscher wrote:I am excited about this device. I placed an order for it this morning and just received email notification that the device was cancelled off of my order. Will this modem/router be available to order again soon? I am confused.
visscher
Jun 17, 2020Aspirant
Yes I ordered directly from netgear.com. It looks like the "Buy Now" button is removed from the product page, so perhaps they listed it for sale too early. I was just hoping to get an update as no explanation was given for the order cancellation.
- FURRYe38Jun 17, 2020Guru - Experienced User
Or ran out of stock.
Something you might ask about with NG support.
- koolkatJul 07, 2020Tutor
Hi, have had the CAX 80 for 2 days. When it works it is amazingly fast as I expected it to be, for the price. I installed using the Nighthawk app, did a firmware upgrade and all was good until the unit "lost" it's internet connection. Rebooted from the app, also rebooted by pulling out the power plug & went through "setup" on the app maybe 10 times now in 2 days. Something is not right, any suggestions. I want this unit to work what can I do?
Thanks
- FURRYe38Jul 07, 2020Guru - Experienced User
Please make a new post in main cable modem forum about this and we'll try to help you out.
Thank you,
koolkat wrote:Hi, have had the CAX 80 for 2 days. When it works it is amazingly fast as I expected it to be, for the price. I installed using the Nighthawk app, did a firmware upgrade and all was good until the unit "lost" it's internet connection. Rebooted from the app, also rebooted by pulling out the power plug & went through "setup" on the app maybe 10 times now in 2 days. Something is not right, any suggestions. I want this unit to work what can I do?
Thanks
