Dustin_V
Jun 16, 2020NETGEAR Employee Retired
Nighthawk AX8 WiFi 6 Cable Modem Router Is Now Available!
NETGEAR is excited to announce that the Nighthawk AX8 8-Stream WiFi 6 Cable Modem Router (CAX80) is now available! An Innovation Award Honoree at CES 2020, the Nighthawk CAX80 is the first of its...
carson_adkins
Jul 09, 2020Apprentice
to bad it doesnt work correctly on xfinity why did you relese it if it doesnt work with xfinity correctly?
- koolkatJul 09, 2020Tutor
Working with Nighthawk Tech support today regarding my problems with CAX 80 dropping the wifi connection multi times during each day. We changed the channel settings for 2.5 ghz to 6 & 5ghz to 48. Here we are 8 hours later & so far no dropped wifi....we'll see how this progresses.
Mike Goodwin
- FURRYe38Jul 09, 2020Guru - Experienced User
Glad you got it working better.
Please make a new post in the cable modem forum for any new problem you find.Enjoy.
koolkat wrote:Working with Nighthawk Tech support today regarding my problems with CAX 80 dropping the wifi connection multi times during each day. We changed the channel settings for 2.5 ghz to 6 & 5ghz to 48. Here we are 8 hours later & so far no dropped wifi....we'll see how this progresses.
Mike Goodwin
- rakng2Jul 29, 2020Guide
Considering purchsing this product to work with xfinity. Where you able to get it to work with xfinity? What was/is the issue? Concerned as Netgear states it is compatible with xfinity.
Thanks!
- FURRYe38Jul 29, 2020Guru - Experienced User
It IS compatible with XF. You'll need to contact the ISP to have them help you get the modem associated with there services.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
rakng2 wrote:Considering purchsing this product to work with xfinity. Where you able to get it to work with xfinity? What was/is the issue? Concerned as Netgear states it is compatible with xfinity.
Thanks!
- carson_adkinsJul 29, 2020Apprenticeit is compatible with Xfinity just had minor bugs that are being worked out as we speak
- rakng2Jul 29, 2020GuideI would like to buy it imminently. Can you please let me know what the minor bugs.
Thanks.
