Dustin_V
Jun 16, 2020NETGEAR Employee Retired
Nighthawk AX8 WiFi 6 Cable Modem Router Is Now Available!
NETGEAR is excited to announce that the Nighthawk AX8 8-Stream WiFi 6 Cable Modem Router (CAX80) is now available! An Innovation Award Honoree at CES 2020, the Nighthawk CAX80 is the first of its...
rakng2
Jul 29, 2020Guide
Considering purchsing this product to work with xfinity. Where you able to get it to work with xfinity? What was/is the issue? Concerned as Netgear states it is compatible with xfinity.
Thanks!
Jul 29, 2020Guru - Experienced User
It IS compatible with XF. You'll need to contact the ISP to have them help you get the modem associated with there services.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
rakng2 wrote:Considering purchsing this product to work with xfinity. Where you able to get it to work with xfinity? What was/is the issue? Concerned as Netgear states it is compatible with xfinity.
Thanks!
