Dustin_V
Jun 16, 2020NETGEAR Employee Retired
Nighthawk AX8 WiFi 6 Cable Modem Router Is Now Available!
NETGEAR is excited to announce that the Nighthawk AX8 8-Stream WiFi 6 Cable Modem Router (CAX80) is now available! An Innovation Award Honoree at CES 2020, the Nighthawk CAX80 is the first of its...
Nov 06, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Not having any problems with my CAX80 on a 1Gb serivce on SparkLight.
rakzo wrote:to be honnest im very disapointed with this product , i have been using netgear product for many years and im very happy last year i decided to upgrade my internet to gigablast with cox and i get theis panoramic wifi when i see this product i get soexited i just wana purchase but at the end after playing arround with few config and testing for few days it was a nightmare i only wish they can fix all the issue especially the connectivity one soon .
rakzo
Nov 06, 2020Initiate
i follow every single steps but unfurtunatelly nothing changed , cox even send a tech to my house to check all connectiong and everything and all was fine
