slappeee's avatar
slappeee
Nighthawk c7000 - NO AIR PRINT, why?
Why can I connect to my air printers using my iPhones?
I have another Netgear WIFI router that I can connect to (on the same network) and have no problems seeing and printing to my air printers from my iPhone.
Why is this?  How do I fix?
-b
  • Figured it out.
    There was an update to the Netgear Genie app. v2.4.54
    There is now a button on the left that was added called "AirPrint"
    This button was not there in the previous version of the Genie.
    Go figure.  Hope this helps somebody else
1 Reply
  • Figured it out.
