LordIsafril's avatar
LordIsafril
Nighthawk c7000 5ghz channel missing from network list
As of 9/26/2017 my 5ghz channel has ceased to appear in my network directory. Before today, it worked and connected just fine. I could fine the assigned channel name and connect with little issue. However, when both my roommate and I came home we discovered the network had disappeared. I have roobted the Router/Modem and even performed a factory reset. The problem is that the device registers both channels are working and broadcasting yet nothing is receiving them. My roommates phone, two seperate Xbox ones and my computer will not read the channel. Where did it go?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Lordlsafril
    Have you tried rename the SSID to something completely different than the old ones you were using just to see if they show up or even removing the password for a test.
    DarrenM
