hlouie96
Oct 26, 2018Aspirant
Nighthawk C7000 AC1900 , disabled router dont know how to turn router back on.
I have aC7000 Cable modem router AC1900 went into the admin and turned off the router trying to hook up the orbi as the router but wont connect to internet, so now looking to turn the router back on in the cable modem router. Cant access the 192.168.0.1 wont allow me to connect to the admin page. Any thoughts or ideas on how to turn the router back on in the cable modem router.
> [...] Cant access the 192.168.0.1 wont allow me to connect to the
> admin page. [...]
Note: "cant" and "wont" are words, different from "can't" and
"won't".
I'd start by trying "192.168.100.1". If that fails, then a settings
reset. Visit http://netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual. Look for "Factory
Settings". You will need to configure the modem+router again (manually)after the settings reset.
- hlouie96Aspirant
Sorry, for delay in replying. The advice given to use the 192.168.0.100 worked and was able to access the admin page and reapply the router.
Thanks for the help.
Henry
