RMPondite
Dec 26, 2020Tutor
Nighthawk C7000 AC1900 how to test if modem/router vs Comcast issue?
All of our devices, both wired and wireless, are experiencing intermitten short access drops -- wired PC screen won't refresh, wifi Roku has connection delays (though it's just 3ft from router), etc....
RMPondite
Dec 27, 2020Tutor
NOTE: I just cleared out the event log to see if i get correct timestamps or 1970 time stamps.
Dec 27, 2020Guru - Experienced User
the t3/t4 errors indicate line issues. The B-INIT-RNG Failure and no ucds received upstream line issues. this indicates the ISP needs to check the line.
- RMPonditeDec 27, 2020Tutor
Thank you! I'll contact Comcast. That's always a fun time... </sarcasm>
I appreciate your help!
- RMPonditeDec 31, 2020Tutor
Well, of course the Comcast phone tech's assertion was "It's the modem" (after he tried several times to sell me on a higher internet speed despite zero indication that I have insufficient speed for what we're doing here), but I pushed until they agreed to set up an appointment for a tech to come out, though he gave me three dire warnings that if they get out there and it's the modem, we'll have to pay a service call fee.
Fortunately the tech who came here heard me out (including the information from this forum), verified my cable modem model and age, and declared that he can't imagine that it would be the modem. He then evaluated everything from the street all the way to the modem, and while he didn't find any one big problem he found 9 different little problems that combined could have easily been the culprit: Several loose connections, a couple of corroded connections, a 4" cable segment, and a part that they stopped using years ago because it was the cause of various intermitten problems. He was so confident that it's not the Netgear equipment that he said that if the problem isn't resolved he'll put in the notes that they need to check the lines from even further back in our neighborhood .
So I haven't looked back at the logs yet but I'm happy with the service that I received today. Thanks again for all of your help!
- plemansJan 01, 2021Guru - Experienced User
glad we could help!
Let us know if there's anything else we can do
