TammyWiFi
Apr 07, 2019Aspirant
Nighthawk C7000 AC1900 Remote Access
I installed the Nighthawk AC1900 Cable Modem / Router in January 2018 in a vacation home. It has been no trouble at all. March of 2018, a neighbor texted me and asked to "borrow" my password to my Wi...
Apr 08, 2019Guru - Experienced User
Are you using the most current updated app? What the app updated any recently?
Does the Nighthawk app work instead of the Genie app?
If you have Administration/Remote Manangement in the modems web page, then yes, remote management should be available to use.
TammyWiFi
Apr 08, 2019Aspirant
I am using the NETGEAR Genie App on my iPhone and it is genie Version 3.1.74. I believe it is the latest version because I don't see any Updates to make for any apps installed on my iPhone.
Does the Nighthawk app work instead of the Genie app? I didn't know there was a Nighthawk App. I am downloading it now. I will be at the house in May, so I can try it out at that time. Thank you!
- FURRYe38Apr 08, 2019Guru - Experienced User
:smileywink:
