mmleach829
May 01, 2017Aspirant
Nighthawk C7000 AC1900 Slow ReadySHARE speeds
I recently tried to start using the ReadySHARE function of the C7000 to archive files on a USB HD attached to the USB port on the C7000. I'm able to connect via the PC but the transfer speeds are VE...
mmleach829
Seagate Backup Plus Hub 4TB (STEL4000100). USB 3.0. It does have its own power adapter. While that exact model number is not on the supported list, I believe it is a newer version of a supported device and I found a post on this forum specifically identifying this model as working with readyshare
May 01, 2017Guru - Experienced User
Might try a different USB drive to see if the same thing happens, even a small USB thumb drive and test.
