Tifflynn83
Jan 15, 2021Aspirant
Nighthawk c7000 ac1900 SLOW speeds inconsistent disconnects
Can anyone help. I switched a few days ago from an old netgear modem/router, I have had numerous drops, cannot stay connected to Remote Desktop, my download speeds are down to 4, sometimes even less....
Tifflynn83
Thanks. We did remove a splitter which we had on with our last modem/router as well without much issue. Didn't seem to help things whatsoever. Have checked over the wires as well.
Jan 15, 2021Guru - Experienced User
You have quite a few errors in the line. If you don't have any other devices in the coax line and its directly connected to the line coming into the home, then I'd contact the ISP to check the line.
- Tifflynn83Jan 15, 2021Aspirant
Appreciate the info. Will do. Like I said, I had very minimal issues until I switched to my new modem/router so just couldn't understand why when the newer one I thought would be much better. Thank you
- plemansJan 15, 2021Guru - Experienced User
It might have been something came loose or didn't need all the working channels with a lower speed setup.
