HWilson0824
Oct 13, 2020Aspirant
Nighthawk C7000 AC1900 unstable connection.
I have only had the C7000 since July 2019. At the current time, the 2.4GHz, 5GHz, and WiFi on/off LED lights are not stable. They blink, stay on some, off some. I have read through other threads on th...
- Oct 13, 2020The ISP had to update the provisioning to the modem/router. Thank you for your help!
Oct 13, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
The wifi LEDS may blink when they are connected too and data flowing to wifi devices, thus showing activity on either radio. Check the user manual for LED behaviors.
HWilson0824
- FURRYe38Oct 13, 2020Guru - Experienced User
Hope that worked. Please mark your post as solved so others will know.
Enjoy. :smileywink:
