jhah135
Feb 07, 2020Follower
Nighthawk C7000 compatible with fios?
Hi everyone! I'm seeking help for my awesome Nighthawk cable modem router. I had Xfinity at my last apartment and now have fios. Is there a way to change some setting(s) so I can continue using...
antinode
Feb 07, 2020Guru
> [...] Is there a way to change some setting(s) so I can continue using
> this router/modem, but only as a router with fios? [...]
Assuming that your "fios" is Verizon Fios, and that that service
provides an Ethernet connection, then sure, _if_ you can "change some
setting(s)" and get your C7000 to sprout a WAN/Internet Ethernet port.
Otherwise, you're out of luck.
Netgear Cxxxx models lack WAN/Internet Ethernet ports, which makes
them almost useless for other purposes. About the only way to repurpose
a Cxxxx is as a wireless access point, not as a full-function router.
