Cindydewelms95
Sep 21, 2017Follower
Nighthawk c7000 genie remote access
im trying to set up remote router mangement. ive enabled it in my advanced router settings but everytime i go to enable it in the genie app it says its not supported but im pretty sure it is can anyo...
vkdelta
Sep 21, 2017NETGEAR Employee Retired
c7000 (Cable Router) DOES NOT support REMOTE-GENIE MANAGEMENT.
It is only on Routers.
- SamssSep 25, 2017Aspirant
Note: the Model C7000 User Manual states:
Remote Management
"The remote management feature lets you access your modem router over the Internet to view or change its settings." This suggests the modem/router does allow remote management.
- vkdeltaSep 26, 2017NETGEAR Employee Retired
this is referrning to HTTP remote mgmt and Not genie remote mgmt.
