Cindydewelms95
Sep 21, 2017Follower
Nighthawk c7000 genie remote access
im trying to set up remote router mangement. ive enabled it in my advanced router settings but everytime i go to enable it in the genie app it says its not supported but im pretty sure it is can anyo...
Samss
Sep 25, 2017Aspirant
Note: the Model C7000 User Manual states:
Remote Management
"The remote management feature lets you access your modem router over the Internet to view or change its settings." This suggests the modem/router does allow remote management.
vkdelta
Sep 26, 2017NETGEAR Employee Retired
this is referrning to HTTP remote mgmt and Not genie remote mgmt.
