nighthawkujzz
Sep 25, 2025Aspirant
Nighthawk c7000 keeps on resetting wifi
I used nighthawk c7000v2 3 years back and then stored it up. I started using it again with Spectrum. However the wifi keeps on resetting once a day. It can happen at any time of the day. I spoke wit...
Sep 25, 2025Guru - Experienced User
How do you know the wifi is resetting?
What do they logs show?
- nighthawkujzzSep 25, 2025Aspirant
I use customized wifi username and password. Now and then, it resets to default. Also, the access to Router also resets to default username and password.
