nighthawkujzz
Sep 25, 2025Aspirant
Nighthawk c7000 keeps on resetting wifi
I used nighthawk c7000v2 3 years back and then stored it up. I started using it again with Spectrum. However the wifi keeps on resetting once a day. It can happen at any time of the day. I spoke wit...
Sep 26, 2025Guru - Experienced User
Could be something either triggered by the ISP or just something corrupt in the settings. I'd do a hard reset by pushing and holding reset while powered on for up to 30 seconds. That should clear everything from memory. IF its a corrupt setting causing it, that should clear it out. If that doesn't help, it could be something hardware related causing the failure.
