Kaaren
Jan 11, 2017Follower
Nighthawk C7000 modem/router set up as a repeater keeps resetting to factory settings
I have set up the Nighthawk as a repeater for my church, but it keeps resetting to the factory default settings and dropping the setups I establish. How can I get it to stabalize?
DarrenM
Jan 13, 2017Sr. NETGEAR Moderator
Hello Kaaren
I would double check the power spot it is plugged into sounds like it could be losing power at sometime. If that is not the issue you may need to contact support if it is still under warranty.
https://www.netgear.com/support/contact.aspx
DarrenM
