sullyb
Jun 22, 2018Aspirant
Nighthawk C7000 set IPv6 DNS enteries
My network has a dedicated DNS server that I have set up (which is IPv4). Recently I noticed new dns server addresses showing up on my clients. Turns out it's my ISP's IPv6 DNS servers being forwarded through. This is a problem because the clients are now bypassing my DNS server. I have been looking at how to overide this on the Genie Web Interface and point it to my DNS with it's own IPv6, but have had no luck finding where I can set/overide the IPv6 DNS settings. Has anyone else seen this and have a fix?
Thanks in advance for any help.
- KitsapMaster
On the R7000 it us under Advanced -> IPV6.
- sullybAspirant
There only seems to be a place to configure the DHCP addresses. No place to set DNS entries.
- sullybAspirant
Still no solution. At this point, I'm going to have to assume that this model is lacking proper admin privileges. More then a bit disapointed in netgear since this should be a basic function. Going to have to turn off the feature in the router and set up a stand alone DNS.
