scifi3dzoo
Jul 10, 2019Tutor
Nighthawk C7000 WiFi router/modem won't connect to Spectrum... no signal detected.
Running fine on Xfinity. Packed it up, moved, got Spectrum svc and they said it won't connect. They put their modem on it works. WTH. Only thing I can think of is something I have to setup in AD...
- Jul 17, 2019
Nothing to modems. ALL FW is handled by ISPs thats given to them by NG. ISP test and ensure the FW works on there systems and doesn't break anything.
If you have a friend, family member that you could take the modem to and see if it works on there cable ISP service, see if the problem follows. If not, then you'll know. Again, if the modem worked with your prior ISP before moving and now it doesn't, I suspect something with the new ISP.
Jul 11, 2019Guru - Experienced User
Try a factory reset on the modem while you have the ISP tech online. If it's supported on there system, and if it worked on the prior ISPs system, then the modem is good and it should work with Spectrum.
Something to have your ISP review with you to see if there is any issues.
Be sure ISP checks signal line quality and levels up to the modem.
Be sure there are no coax cable line splitters inbetween the modem and ISP service box.
scifi3dzoo
Jul 13, 2019Tutor
RESET did nothing. I'm gonna just complain to BBB or something. It's a 2 year old modem. I know they don't want people using support on their dime to ask setup questions but I have a HW issue I think. And I should be able to mail it in for repairs with all the trouble, and pay $50 or whatever it is just to get warranty/repair set up. I'm done with Netgear after this.
- FURRYe38Jul 13, 2019Guru - Experienced User
It's not a NG problem if the modem doesn't work or is not getting fully connected to the ISP. IF the ISP supports the modem, then it's up to the ISP to check and geting associated. If it worked with your prior ISP then the modem is probably good. Should blame NG for something they can't effect with ISPs.
- scifi3dzooJul 13, 2019TutorIt is supported. And I think every ISP supports that modem. We tried everything it's just not detecting a signal
- FURRYe38Jul 14, 2019Guru - Experienced User
Kind of hard to imagine it working at a prior ISP service then not working at the next. Unless the unit was somehow damaged in your move from one location to the other.
