shawnconaway
Sep 14, 2019Aspirant
nighthawk c7000
My Nighthawk AC1900 Wifi Cable Modem Router Model C7000 seems to be getting hot and even hotter at the broad band cable connection was wondering why and how to correct it?
Sep 14, 2019Guru - Experienced User
Getting hot doesn't tell us much.
Is it malfunctioning?
How hot is getting hot? These devices generate heat due to the processors in them. Some of the newer ones even have fans on them for active cooling.
The c7000 is designed to run standing up and has plenty of air holes for cooling. Is there anything around it blocking the airflow or is it not standing up?
- shawnconawaySep 14, 2019Aspirant
i put a small fan next to it and have it blowing on it lot cooler before it was hot enough that didnt want to touch it. seems like it is working fine just some times takes awhile to connect to the internet like 2 to three minutes.
- plemansSep 14, 2019Guru - Experienced UserHow's your coax coming in? If you check your connections page can you post a screen snip of that page?
