shawnconaway
Sep 14, 2019Aspirant
nighthawk c7000
My Nighthawk AC1900 Wifi Cable Modem Router Model C7000 seems to be getting hot and even hotter at the broad band cable connection was wondering why and how to correct it?
shawnconaway
i put a small fan next to it and have it blowing on it lot cooler before it was hot enough that didnt want to touch it. seems like it is working fine just some times takes awhile to connect to the internet like 2 to three minutes.
Sep 14, 2019Guru - Experienced User
How's your coax coming in? If you check your connections page can you post a screen snip of that page?
